Was driving the car for months of trouble free bliss and all of a sudden it started bucking and jerking. Then stalling. Changed all spark plugs , map sensor , and 1 coil pack on the cylinder the scan tool said was mis firing. Still runs the same. Help !!!
Anyone ???
Shot in the dark....Battery?
If the battery is 3 years or older I’d suspect it. Batteries can TEST at correct voltage but you should have it LOAD tested.
Better yet, if the battery is that old, replace it.
Had a 200 where the battery was discharged. Jumped it and it ran like crap. Put a new battery in and it ran fine.
06 300c 113k miles I have said issue when the gas tank is full supposedly overfill switch is ome faulty for most DO NOT TOP OFF FUEL was my solution
Discussion Starter · #6 ·
Believe it or not the car has been sitting untouched. I had one person say that a fuel situation and not a engine situation where there was a clog.
