Hello Two days ago my upgraded MyGig FM radio started dropping out for about 3-5 seconds every few minutes (you can still hear it feintly) Then it resumes normal volume I've tried adjusting the volume while it is 'out' but the unit does not respond Anyone had a similar problem? I haven't tested to see if it does it on CD etc as yet I have tried changing radio station and it does it on all FM stations Any help/advise/suggestions would be greatly appreciated Should I reset it to factory settings and see if that helps?
