im running 265 35 22 pirelli tires with the 22X9.5 tis style 03 and i dont have any problems at all, except when i turn the wheel all the way around i get alittle bit of rubbing. :banana: :smoker:aspendog said:on a 22x10 and 22x8.5 staggared +15mm offset setup? I wanted to reuse my tires but I think my 285/30/22 on a 8.5" wide wheel is not the appropriate setup.
Aspen,aspendog said:on a 22x10 and 22x8.5 staggared +15mm offset setup? I wanted to reuse my tires but I think my 285/30/22 on a 8.5" wide wheel is not the appropriate setup.
thedon01 said:265 35 isnt going to fit a 11 inch wide wheel it barley fits the 9.5 he has to go with either a 285 35 22 or 295 30 22 yes it has less side wall but fits pefrect
Mike5959 said:I am planning on running staggered wheels 8.5 front and 10" rear. I ordered 265/35/22 front and 285/35/22 rear. do you think that will be an issue?
aspendog said:What tires? I can not find a matching set of tires w/ those sizes. There is a BFG 285/35/22 but not a 265/35/22. I went with the Nitto 420s 295/30/22 and 265/35/22, I will report what happens, had a few guys state they are running it w/ no issues.
Mike5959 said:I am going with Hankook. Now believe me I have never though about running these in the past as the name kinda turns me off. I have been a huge Toyo fan and BFG fan. My friend has the hankook 265/35/22 on his '03 Harley F150 and it rides awesome. I figure if a full size supercharged truck can run well on these and handle great with no issues then my measily car should be awesome on them. I also checked the rating on the tire and hankook was rated higher than the Kumho.
aspendog said:Great, let us know how things go...
saleensean said:we did a customers magnum with 265/35/22 on an 8.5 in front and 295/30/22 on a 10.5 in the rear. the rear rubbed a little because it was lowered a lot.
What kind of wheels are :fing02: thoose?VIPedition said:Aspen,
Here is a car we did w/ 265/35/22 in front w/ 295/30/22 in the rear. The rear is running a 11" wide
13.6" offset? Huh? Do you mean +13.6mm? Even so, never heard of that kinda offset.aspendog said:I went w/ the 295/30/22 on a 22x10 13.6" offset and had slight rubbing in the rear but after a small fender roll everything is fine.
