I had a stereo shop install an old Rockford Fosgate 800a2 Power amp and two 12" Fosgate HE2s in a sealed box (that my friend used to have in his BMW) in my 300C(sound group II w/ Nav). The setup sounded pretty good in his BMW but it isn't up to par in my C. They used a converter off the rear deck speakers. The speakers barely moved. Apparently the signal wasn't strong enough so they installed an Audio Control Overdrive line driver to boost the signal. With the gain on that all the way up, I am getting somewhere between 2 and 5 volts. The 2V light flashes, but not the 5v. With the gain nearly all the way up on the driver and the amp gain set a bit more than halfway, the bass would be "OK" but then the amp would eventually overheat. I backed off the gain on the amp just slightly and solved the overheating, but the bass level dropped far below what I thought was normal. I have 4 ideas as to what my problem is.....and would appreciate any suggestions you pros might have.
1. The RCA converter needs to be installed between the head unit and the factory amp. I believe the factory amp may be processing the signal and cutting off some of the low frequencies needed to get to the sub. The subs hit well at some frequencies, but some low frequencies just aren't there.
2. I checked the subs with my multimeter and they are only putting an 8 ohm load on the amp. The amp is 4 ohm stable bridged. Maybe replacing the speakers with better ones with bigger magnets that have dual 4ohm voice coils wired in series-parallel to place a 4ohm load overall would help so I could get max power out of the amp.
3. The speakers need to be in a vented box or bandpass to extend the lower frequencies. (If this is the case, I have considered just getting a better sub and running one 12" to save some space.
4. Maybe I am just used to my truck which has four 12" Rockford DVCs in the rear cab.
Any suggestions??
Any suggestions??
