1 - 1 of 1 Posts
If anyone has a rear (STOCK, not the Nivomats) shock off the vehicle (300C), I need:
1) Picture each of upper and lower shock mount (lower eye, upper stud/bracket)
2) dimension from the center of the lower eye to the plate on the top stud with the shock fully compressed
3) same dimension as above, only with the shock fully extended.
4) overall picture of the shock.
I need these so I can start researching through my supplier sources to find a suitable heavier valved rear replacement shock for use with 1" - 2" dropped springs. I have found the rear needs a bit more valving control over the stock shock to control see sawing on major undulations in the pavement at speed.
I will post up results of any brands/part numbers I find that look to be a solution.
Thanks,
Mr MoPar
1 - 1 of 1 Posts
