Ok, I talked to my datalogger rpovider and they asked us to pick 5 items from the enhanced list an they would look into what it would take to add them to the base package as an additional incentive to the LX crowd. Development will start next week after we've picked our 5.
Here's the list; pick 5 data parameters to add to the Logging list:
Base Spark($02
Battery Temp($01
Battery Temp Voltage($01
Cam Crank Difference($05
Closed Loop Operation of ICC($03
Correction for VE - Bank 1 Cell 00($05
Correction for VE - Bank 1 Cell 24($05
Correction for VE - Bank 1 Cell 25($05
Correction for VE - Bank 2 Cell 00($05
Correction for VE - Bank 2 Cell 24($05
Correction for VE - Bank 2 Cell 25($05
Crank Limp Home Strategy($05
Cranking Injector Pulse Width($04
Current ADAP Cell ID($04
Cylinder 1 Mis-Fire Counter($07
Cylinder 1 Mis-Fire Service Counter($07
Cylinder 1 Pre-Cubed Data($0
Cylinder 2 Mis-Fire Counter($07
Cylinder 2 Mis-Fire Service Counter($07
Cylinder 2 Pre-Cubed Data($07
Cylinder 3 Mis-Fire Counter($07A
Cylinder 3 Mis-Fire Service Counter($07
Cylinder 3 Pre-Cubed Data($07
Cylinder 4 Mis-Fire Counter($07
Cylinder 4 Mis-Fire Service Counter($07
Cylinder 4 Pre-Cubed Data($07
Cylinder 5 Mis-Fire Counter($07
Cylinder 5 Mis-Fire Service Counter($07
Cylinder 5 Pre-Cubed Data($07
Cylinder 6 Mis-Fire Counter($07
Cylinder 6 Mis-Fire Service Counter($07
Cylinder 6 Pre-Cubed Data($07
Cylinder 7 Mis-Fire Counter($07
Cylinder 7 Mis-Fire Service Counter($07
Cylinder 7 Pre-Cubed Data($07
Cylinder 8 Mis-Fire Counter($07
Cylinder 8 Mis-Fire Service Counter($07
Cylinders that Misfire During 200 revs($07
Engine Runtime($01
Engine Speed($01
Engineering Misfire Fail Status($07
ETC In-Plant Flags($9E
Fast Moving Average Bank 2($06
Filtered RPM($01D7)
Filtered Throttle Position Sensor Voltage($01
Flex Fuel Vehicle Ethanol Percent($9E
Fuel Lean 1 Monitor Status($07
Fuel Lean 2 Monitor Status($07
Fuel Level($04
Fuel Level Percent
Fuel Level Sensor Voltage
Fuel Prime Time($9E41)
Fuel Rail Bleed: Maximum RPM
Fuel Rail Bleed: Maximum Time
Fuel Rail Bleed: Minumum RPM($
Generator Duty Cycle($0
Global Delay Time To Start In-Plant Testing (Engine Running Portion)
IAC Current($0
IAC Pulse Width($0
IAC total AirFlow($03
ICC External Device Control($0
ICC Mode of Operation($0
ICC Switch State($03
Idle Speed High RPM Set Point($9
Idle Speed Hysteresis($9
Ignition Dwell Cylinder 1($0
Ignition Dwell Cylinder 2($0
Ignition Off Time($0
Injector Pulse Width Cylinder 1($04
Injector Pulse Width Cylinder 2($04
Knock Sensor 2 Volts($03
Knock Sensor Volts($03
Large Leak Monitor Status($06
Last CAT MON 1 Freq Ratio($06
Last CAT MON 2 Freq Ratio($06
Low Oil Maximum Timer($9E
Manifold Air Pressure($01
MAP at Time of Bank 1 Failure($07
MAP at Time of Bank 2 Lean Failure($07
MAP at Time of Bank 2 Rich Failure($07
MAP at Which Engine is Misfiring($0
MAP Vacuum($01
Oil Pressure Sensor Voltage($04
Open Throttle Timer($01
Output Configuration($80
Base Spark($02
Battery Temp($01
Engine Runtime($01
Engine Speed($01
Filtered RPM($01D7)
Fuel Level($04
Fuel Level Percent
IAC Current($0
IAC Pulse Width($0
MAP Vacuum($01
