Howdy,
So I just bought a 2005 300C w/ 92k miles on it. I havent owned one before, so just some basic questions and few issues:
*Check engine light came on same day I drove it off the lot (save you the venting)... One code was catalytic Bank 2, the other was the "wrong oil" one which was fixed with a simple oil change. For the catalyitic failure code, how likely is it that it is just the O2 sensor? Is there an easy test to find out? Due to how low the cars are, is it difficult to work underneath with just a car jack?
*The tire pressure light is on after getting new tires. I havent checked the pressure yet, but is it common to just turn this system off? How often is it incorrect?
*When looking for new parts, where do you shop online? I can search for 2005 300C Catalytic converter, but most sites done seem legit, and often dont clearly show what you are buying. Best to just go into an autopart store?
*Windshield fluid not spraying, although it does at the headlights. Do these use the same sprayer motor?
* The back bumper looks to have back-up sensors, although I havent heard the car beep or anything when backing up near something. IS there a chance the car does not have it, but they all use the same looking bumper?
* What is the small clear sensor on top of the dash where the dash meets the windshield in the center of the car?
