Sorry pictures will come tomorrow when I have daylight. My last picture in the garage using flourescent light just flat out sucked. I bought the cheap ass ABS grille with the chrome mesh and it looks freaking fantastic! Best $250 I've spent in a long time! I plan on blacking it out at some point but I'll drive it as is for now.
All the posts I searched here talked about pulling the front portion of the grille down and just cutting out the old grille. DON'T DO THAT. Taking off the bumper cover is super easy. I rate it 3 out of 10 beers. You don't need to unplug wire harnesses or remove the washer fluid and tube. You just take off a series of screws, bolts and push pins around the front. Takes about 1 hour for the entire install. Unless you're a clean freak like me and decide to degrease and clean every little piece you can now access. I swear I have OCD.
Any who, no big deal, but a huge improvement. I also relocated the license plate since the factory piece won't attach to the new grille. Just drill straight into the bumper cover. Yes it sucks, but in VA we have to run a front plate.
The emblem mod again was super easy. Trained a blow dryer on the "300 Hemi" emblem on high for about 5 minutes. You'll know it's ready when you can begin to lift up one edge of the emblem and it starts to pull away easily. Carefull because it's seriously freaking hot. I have a plastic tool that is used to put 3M clear bra's on so I just worked that in behind the emblem. When done, there is a little residue from the adhesive. I used Stoner's Tarminex to soak the residue and then just rub it off. Applied the SRT-8 emblems in the same position. Look great! Pictures tomorrow.
