1 - 10 of 10 Posts
Hey guys, I have a 2012 Chrysler 300S. The headlight went out and after replacing it, it still doesn't work. Now, to be honest, I slacked long enough replacing it that they both went out. I went to the store and bought two headlight bulbs and the drivers side worked after replacement. So I swapped them out to make sure the bulb wasn't bad and the one known to be good didn't work on the passenger side. I fiddled the wires and everything looks ok... even though it's hard to get a good look.
I am under the impression the ballast is built into the bulb but I'm not positive. It's a bulb with a 1 inch square at the base.
The car uses the 100 HID bulbs and the lights also turn as I turn the vehicle... I can't remember what that's called.
Any ideas what's wrong?
2006 CRD Touring
Something odd here, as HID bulbs are designed to last for more than 3 years. I've just replaced mine after 8 years. The square box at the base is not the ballast, which is located under the headlamp unit. Also, you need to be sure that replacement bulbs are of OEM quality.
the main ballast is affixed to the base of the headlight capsule. I suspect the main ballast has failed since you tested that side with a known, good bulb.
Discussion Starter · #10 ·
Well that's a bummer... that ballast looks like a pain to replace. I suppose that's pretty expensive to have replace at the dealer right?
1 - 10 of 10 Posts
