1 - 10 of 10 Posts
Thanks Kev for posting the picture
Few questions
- did you notice if they were externally adjustable for damping rate?
- they appear to be low pressure gas, can you confirm?
- there are springs for the front, did you see any for the rear struts, and can you confirm the rear springs are included?
- The rear shocks appear to come with spring collars, and therefore would be actual coilovers as opposed to the KW set of adjustable damper unit and seperate spring - see attached image - can you confirm actual coilovers in rear?
Thankyou Kev
Sounds a lot like KW Variant Is or the Eibachs.
How in the heck do you adjust ride height in the rear?
Mopar suspension kit for AWD
knickknack22 said:
would these work on an AWD?
I posed the same question of application to the 300C AWD to mopar.com.
Their resonse will appear on their website shortly.
Keep Watching!
larbo53 said:
Cost???? :deal:
Availability? I was debating the Mopar lowering springs, but this might be a better idea.
1 - 10 of 10 Posts
