· Premium Member
TSB#: 21-013-05
Date: Aug 04, 2005
Subject: A/C Cooling Coil Odor
Models: 2005-2006 300 and Magnum (+ many other DCX vehicles 1993-2006)
Overview: This bulletin involves inspecting for leaves and other foreign material, cleaning, and treating the cooling coil and housing.
Symptom/Condition: Some vehicle operators may experience a musty odor from the A/C system, primarily at start up in hot and humid climates. This odor may be the result of microbial growth on the cooling coil. During normal A/C system operation, condensation forms in and around the A/C cooling coil. When airborne pollutants mix with this condensation, bacteria and fungi growth begins and odor results.
Diagnosis: If the operator describes, or the technician experiences a musty odor when operating the A/C system, perform the appropriate Repair Procedure based on the vehicle model.
Note: This TSB involves extensive procedures too long to list here, the bulletin is 11-pages long. If you need a copy of the bulletin PM me your email address.
BG Frigi-Clean is a product used to fix this on many cars. Available at specialty A/C repair shops. I've looked a several chain repair shops, that also do A/C services, but none here carry the product or offer the service. My 300M has this smell and I wanted to get it cleaned. It's a foam that's injected into the system and cleans the evap coil to eliminate the problem.
· Premium Member
The problem described seems to be a feature of Hondas. My wife's Prelude did this and the dealer had no fix for it over the years we owned the car. When we were in Miami last year we got an Accord rental and that had the smell and even fogged the windows when it was started after standing for a while. A work collegue has a new CRV and he reckons his is bad too. So much for Honda technology.
This article in 1997 concluded
Simmons believes a solution will be found to 'sick car syndrome'. "The automobile industry is aware of this," he said, "and they're making moves to improve the materials used to build the A/C systems, to help prevent this."
http://www.anomalous-images.com/news/news041.html
Here we are, 8 years later, and Chrysler still hasn't figured it out.
The problem is considered so bad it was even grounds for the Lemon Law.
http://www.lemonlaw.com/carsick.html
Eric, is the smell like rotten eggs?
Anyways on A/C smell, which seems to be a very common phenomenon over the last 10 years, a way to prevent it is shut off your A/C 30 seconds (or better yet 1 minute) before you park the car.
TSB#: 21-013-05
Date: Aug 04, 2005
May I get a Copy of that. I have ordered some BG Fresh and just need to know how to get it right. Thank you Jim Cogan.
