TSB#: 19-002-06
Date: February 16, 2006
Subject: Moan/Groan Sound Heard At Idle
Models: 2005-2006 LX (300/Charger/Magnum) and 2006 LE international models
NOTE: This bulletin applies to vehicle equipped with a 3.5L Engine (Sales Code EGG).
Overview: This bulletin involves installing a revised power steering pressure line clip.
Symptom/Condition: Moan/Groan sound heard while turning the steering wheel right or left when the vehicle is at normal operating temperature and the engine is at idle speed.
Diagnosis: With the vehicle at normal operating temperature and the engine at idle speed (600 rpm), turn the steering wheel 90° right and left with the A/C on. Turn the A/C off and repeat turning the steering wheel, if the moan/groan sound is present with the A/C off perform the Repair Procedure. If the moan/groan sound is NOT present with the A/C OFF, this bulletin does not apply and further diagnosis is required.
To download a copy of the TSB in PDF format see the master listing sticky thread: http://www.300cforums.com/forums/ts...list-all-tsbs-issued-2005-2006-lx-models.html
