1 - 16 of 16 Posts
Hi,
I have a 2007 touring and I found a post on craigslist for a 2006 300c front bumper for cheap so I picked it up. Now I need some help with making sure I have everything I need to install it.
From what I've read about and heard, I need the 300c headlights and fog lights and that is all. Is that correct?
I am looking to put the 300c Factory HID headlights in that have the balasts. They are part number 0485862AG and 04805759AG. Will these be plug and play with my touring wiring or will I need to do more to get them to work? If I need to do more, what do I need to do?
Where can I find OEM fog lights? I seem to only find the touring ones, not the 300c ones. Will 300c ones work with touring wiring?
Is anything NOT going to be plug and play. I only get one day off a week and I cant be without a car so I am trying to make sure that I have all my ducks in a row before I start the conversion and discover something doesn't work and then have to go in reverse and put it back together like it was supposed to be.
IF ANYONE HAS ANY ITEMS I NEED FOR THIS CONVERSION AND IS LOOKING TO SELL THEM, PLEASE LET ME KNOW.
Discussion Starter #2
pics
Here are the pictures of the bumper. As you can tell its missing some trim below the headlights. Where can I find that trim (what is it called)?
Im pretty sure the bumper and head lights are directly bolt on. The fogs will bolt into the bumper. As far as HID's go, id say go with one of our supporting vendors kits, we know they work and theyll prob be cheaper than the OEM kit.
Heres the site for AAC's OEM Headlights
2005-'08 Chrysler 300C OEM Headlights
Heres the site for OEM Headlights, Fogs, and wiring harness. This will for sure give you everything you need for the conversion as far as lights go
300 Base, Limited, & Touring Model to 300C Conversion Kit
I hope this helps, and im going to be doing this conversion too, so let me know how it goes!
u need 300c fog lights for sure they are a different size from ur touring and also the headlights look different to and also headlamp washers and the chrome trim
ok. Thank you. I read somewhere that the OEM xenon headlights will only fit cars that have the xenon HID headlights as a factory included option. Does anyone know if the OEM xenon headlights are different in shape and size of the rear of the housing as compared to the AAC 300c headlights. Even on the AAC site it says that the headlights will fit 300c WITHOUT xenons.
is this a wiring issue (which can be fixed with new wires) or a shape issue (that will require body work to make fit)
I have the foglight plastic housing for a 300c. There's a chance I might need them in the future. If you can't find any, hit me up and I'll see if I'm willing to let them go.
If you just need the part number, let me know. I'm not at home right now but I can get the # if you need me to.
that would be great. there is no way the touring housing will work on a 300c?
That I'm not sure of.
When I get home, I'll take down the part number and post it up. That'll probably be a couple of hours from now.
Oops. I kept forgetting to get the part number. Sorry for the delay. Here it is though
04805858AA
Good luck
correction, yes the touring fogs will fit in the C bumper with the touring housings. how do i know? because i did it last year on my touring. all you have to do is break the corner tabs off that go into the touring bumper and make 4 screw holes in the four corners of the touring bracket and screw the housing with the fog light in it in to the C bumper with screws. easy job
Makaveli, I absolutely LOVE that Jumpman logo. Everytime I see a pic of your car, I always notice it.
1 - 16 of 16 Posts
