I was going to mention that lock. The brake pedal is said to be the strongest part of the car. The "Club" is put to shame against this lock. Very nice design.5point7 said:If anyone hasn't seen the "unbreakable" auto lock pro - I use one on my Vert. It locks the brake pedal in place. Won't prevent a flat bed from coming and taking your ride (nothing will if they want it), but they would not be able to drive the car. With the rest of the anti-theft features it's a great tool to use.
http://www.unbreakable.com/Unbreakable_Auto_BL.htm
Well, as those go...if a thief has a few minutes and a hack saw, all they need do is cut the actual pedal off the metal 'arm' and off goes the auto lock. Then it CAN be driven away (the thief just needs to keep a foot on what is left of the stalk to keep using the brake easily).5point7 said:If anyone hasn't seen the "unbreakable" auto lock pro - I use one on my Vert. It locks the brake pedal in place. Won't prevent a flat bed from coming and taking your ride (nothing will if they want it), but they would not be able to drive the car. With the rest of the anti-theft features it's a great tool to use.
I never said it would be easy, I simply indicated that even with one of these items, a can CAN be driven.5point7 said:Not that easy jjs, but if someone wants your car bad enough, they will get it regardless of what you have. Quickness is key in stealing - if it's not quick and easy they mostly move on.
REALLY? I don't trust everything I see, but the makers of the pedal lock say that a hack saw would take an hour to hack through the pedal metal.jjs said:Well, as those go...if a thief has a few minutes and a hack saw, all they need do is cut the actual pedal off the metal 'arm' and off goes the auto lock. Then it CAN be driven away (the thief just needs to keep a foot on what is left of the stalk to keep using the brake easily).
True, true!Northern Rider said:Theft prevention is difficult. Only a GPS tracking system alarm will be of any real use for quick recovery.
True blue!!! Nailed it.Model 57 said:First300Owner; that is why you have the secondary back-up, (the gun) that you mentioned in your earlier post. At least if you know it is being stolen, and you can get to the approx. location, you may be able to stop them.
