Hello everyone!
I have a 2004 Сhrysler 300c with a 3.5 liter engine.
I tried to search the forum, but did not find a similar problem.
So, the car should switch on a low fan speed at a temperature of 103 C (217 F) and high speed on 110 С (230 F). As the name implies my first speed does not turn on, however i checked the fan and both speeds are working. Then, as shown in the diagram, I closed contacts 30 and 87 on the relays marked 1 and 2, and the fans turned on again in both cases. Then I began to measure the voltage on pins 85 and 86 of relay numbers 1 and 2. And the voltage appeared only when the engine reaches temperature 110 С (230 F).
It is very strange, as if ECU does not send a signal to turn on low speed. Maybe someone has met something like this? The problem could be somewhere else besides the control unit? Can the trigger temperature be adjusted in the firmware?
