Can you hear the radio at all? I would say to see if the mute button was pressed by accident.BryanS said:The volume stopped working completely! Has anyone else had that problem? Anyone know what the fix is? The NAV voice comes in but I can't raise the volume.![]()
I've had my car for about 1 1/2 months. I've had a similar problem several times (10 maybe). I listen to sirius radio, but when I get back in the car and start it, I notice it is on FM with no volume. I turn the volume up and down but nothing. Then I press the music note button on the steering wheel to change it back to sirius and everything returns to normal. I'm guessing my issue is a software bug. I'm on the latest version (3.61) so maybe there will be a fix soon as I've seen a few other posts complaining about the same issue. I have the radio II package with no Navigation.BryanS said:The volume stopped working completely! Has anyone else had that problem? Anyone know what the fix is? The NAV voice comes in but I can't raise the volume.![]()
My 300C does the same thing but I have software version 3.60 (Dealer has a problem upgrading the software). And I use the same solution.dsharp said:I've had my car for about 1 1/2 months. I've had a similar problem several times (10 maybe). I listen to sirius radio, but when I get back in the car and start it, I notice it is on FM with no volume. I turn the volume up and down but nothing. Then I press the music note button on the steering wheel to change it back to sirius and everything returns to normal. I'm guessing my issue is a software bug. I'm on the latest version (3.61) so maybe there will be a fix soon as I've seen a few other posts complaining about the same issue. I have the radio II package with no Navigation.
Yep, I had read that, but I the rest of the symptoms were the same. I just wanted to mention that someone stated that the amps were throwing error codes and that was supposedly what was causing the problem.jeepgrady said:But, as I stated in my thread, I couldn't switch to Sat. The radio wouldn't let me.
