After my day at the track I have to replace my OEM Contis.
BFG have a new performance series out: GForce T/A KDW-2
Has anyone put these on their car? The performance stats are great and the price is right - 255/55VR/18 is $128.00 at TireRack.
I plan to pick up a set of Magnum R/T rims (very light - under 25 lbs) and mount these as a summer tire / track tire.
The BFGoodrich g-Force T/A KDW-2 (KDW for Key feature: Dry and Wet traction, the “2” is our addition and identifies that this is the second generation g-Force T/A KDW) is the Ultra High Performance Summer tire that was developed to provide a blend of a dramatic-looking, ultra high performance tread design with superior dry and wet road performance. The BFGoodrich g-Force T/A KDW-2 is available in sizes for drivers of the world's hottest sports cars, coupes, sedans and light trucks.
The g-Force T/A KDW-2 features large tread blocks to enhance dry road stability, handling and wear under high torque loads, while rounded shoulder profiles help provide feedback for the driver by communicating the tire's progressive and predictable characteristics as they reach their limits of adhesion. A silica-reinforced tread compound with wide circumferential and lateral grooves form a directional tread design to speed water evacuation, improve wet traction and reduce the risk of hydroplaning. This basic tread design technology is shared with the g-Force T/A radial racing rain tires used in the Sports Car Club of America (SCCA) Trans Am Series. Internally, the twin steel belts are reinforced by BFGoodrich's ETEC (Equal TEnsion Containment) System which uses spirally wound nylon strips to provide excellent strength, consistent footprint pressure and maximum contact area under Y-speed rated conditions while it reduces weight and helps provide more uniform ride quality. The g-Force T/A KDW-2 tires feature g-Control sidewall inserts to resist deflection and generate cornering force while rim protector ribs help protect alloy wheels from curb damage.
The g-Force T/A KDW-2 tires feature subtle black letter styling and will initially be available in selected sizes. Sizes will expand throughout the year to include 60-, 55-, 50-, 45-, 40-, and 35-series, V- and Z-speed rated sizes for 17" to 24" wheel diameters.
Click small images below to view larger.
