Hey guys, I just purchased an ‘05 300C with 100K miles. The power with the Hemi is incredible and the style lines are cool. It is the Daimler Chrysler so it has some of that Mercedes technology in it. What issues should I watch out for in the future? Thx.
The most important issue is the potential for a dropped valve seat.
There isn't much you can do to prevent it, other than to keep your cooling system in good condition and avoid shutting off the engine when it's too hot.
My suggestion is to install a 195° thermostat and use a handheld tuner to lower your fan temps about 10° across the board.
Make sure your cooling system is filled with a clean, fresh 50/50 mix of HOAT coolant and distilled water.
Keep on eye on your engine temps. If they get too high, say from idling in traffic with the A/C on, make sure you allow it to cool off before shutdown.
2014 CRD
Make sure you keep your air filter clean!! I would also recommend a oil catch can plus as also mentioned keep it cool , cool , cool and enjoy the ride
Please, please check the dates of posts you're replying to. You've just resurrected a 2 year old thread where the OP hasn't posted on the site since the original post above
2013 Chrysler 300 SRT8
Broken record on this forum. I've never seen so much of it honestly.
