HEMEEE said:
For the surface scratches you will need to get it Buffed, limited success by hand, for your chip, here is a post I did a while back on that.
Tip #7: Paint Chip Repair Made Easy
None of us can avoid those darn paint chips. They annoy us every time we wash our car when we see them. They also seem to grow in size and dimension every week.
Well, we can do something about it, short of a costly body shop visit. Here are some things you will need first: factory touchup paint, a pack of artist brushes (you can buy these at any craft store for under 5 bucks) a can of Acrylic Lacquer thinner, old rags, piece of cardboard, and a small container.
I tell people is to wash their car first. The reason for washing is that many times a blemish may be removed during the cleaning stage, thus you won't not need to touch it up.
Begin by taking some of the thinner and pour a small amount into a container. Shake your touch up paint well (most factory paint is thick).
Have your small piece of cardboard and an old rag next to you. Put about a dime size amount of paint on the cardboard, pick out a brush the correct size that will match the size of the chips you are working on.
The problem with the brush supplied with the paint is that it is large enough to paint your garage doors, NOT your chips. Always remember this, "less is best". You can avoid those unsightly "blobs" by using less paint.
Take your brush and put it in the thinner, dab dry. There will still be enough thinner in the brush to thin the paint. Apply the brush to the paint, moving it around. You will be thinning the paint just enough to make it easy to work with.
Now go to your chips and lightly touch them. *NOTE, the paint will dry fast on your brush; you might only get to one chip at first before the brush gets dried out and the paint gets stiff. Just simply start process over again, and move on to your next chip.
Once you get the hang of it, you might get 2-3 chips done before you need to thin again. After 24 hours, you have the option of putting a coat of clear on (nail polish works for this as well) which you can get at an auto supply store.
Some have told me that leaving it just with the paint works fine, without the clear. Try a hidden area with the clear first and see how it looks before you move on.
