Thanks Jack, i have a downloaded manual on my laptop so i'll take a look, do you think it would be possible to use the existing sensors on an after market setup if it turned out the module was dead?
As Badgx says. No chance at all of using existing detectors on an aftermarket module.
I have dug this attached layout of pinouts on Module which saves searching through drawings.
It would be worthwhile to at least check the 12V supply, the Canbus 2.4Volts and make sure the chassis connection has zero volts on it and has continuity to chassis.
Then disconnect all 4 sensors, compare continuity of sensors and check there is no continuity to chassis on a any sensor pin)
As a last resort I would even try disconnecting all 4 sensors and power it up without the sensors plugged in to see what happens. (I'm sure it wont damage the module running with no sensors connected, modern electronics are well designed to protect against that type of damage now)
A dealer would know in seconds if the module was recognised on the system with their Starscan but at an hour labour.
An oscilloscope would do a similar job but checking for 2.4V on the CanBus would prove that no wires are O/C on the Bus.
Jack
