Got a 2008 CRD, and have the usual issue of the rubber fuel pipes weeping, so want to replace them all. Had them done not long after I had the car just using some standard fuel pipe, but ideally I'd like to get the genuine article pipes (provided they're not too dear!)
What I need is the part numbers for the two small rubber pipes near the alternator, the two small rubber pipes going to the fuel filter, and also the large pipe that runs from the front of the engine out back (I believe it's the one leading to the high pressure pump). I'd also like to know if the same pipes are used on any Mercedes models, and if so the Merc part numbers as well. I've found some on Ebay, but no-one seems to know if they're the right ones, and the parts manual serves only to confuse as I can't find any mention of the pipe leading to the HP pump!
Cheers
JD
Cheers
JD
