Guys
Just downloaded the 2008 one from Sox's site and I can't view anything. Do I need to cut this to disk first and use it from a CD. I thought I could just run default.htm and use it in IE (Chrome). Just wanted to get some torque wrench settings for Track Rod Ends.
what are you trying to look at it with? Whats your operating system?
normally its a compatibility issue - hit f12 & select '7' rather than 'edge' or settings more than 7 in 'document mode'
in any case, this is from the 2008 manual ....first number is NM, 2nd number is Ft/Lbs, 3rd number is in/lbs (but often shows as " - " (blank))
FRONT SUSPENSION FASTENER TORQUE
[SIZE=-1]
DESCRIPTION
[/SIZE][SIZE=-1]
N·m
[/SIZE][SIZE=-1]
Ft. Lbs.
[/SIZE][SIZE=-1]
In. Lbs.
[/SIZE][SIZE=-1]Engine Cradle Mounting Bolts
[/SIZE][SIZE=-1]185
[/SIZE][SIZE=-1]136
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Hub And Bearing Mounting Bolts
[/SIZE][SIZE=-1]68
[/SIZE][SIZE=-1]50
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Hub Nut - AWD
[/SIZE][SIZE=-1]213
[/SIZE][SIZE=-1]157
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Hub Nut - RWD
[/SIZE][SIZE=-1]250
[/SIZE][SIZE=-1]184
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Knuckle Dust Shield Screws
[/SIZE][SIZE=-1]10
[/SIZE][SIZE=-1]7
[/SIZE][SIZE=-1]89
[/SIZE][SIZE=-1]Lower Control Arm Cradle Nut
[/SIZE][SIZE=-1]176
[/SIZE][SIZE=-1]130
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Lower Control Arm Ball Joint Nut - AWD
[/SIZE][SIZE=-1]68 + 90° TURN
[/SIZE][SIZE=-1]50 + 90° TURN
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Lower Control Arm Ball Joint Nut - RWD
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Tension Strut Cradle Nut
[/SIZE][SIZE=-1]176
[/SIZE][SIZE=-1]130
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Tension Strut Ball Joint Nut
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Shock Absorber Clevis Bracket Lower Bolt - AWD
[/SIZE][SIZE=-1]174
[/SIZE][SIZE=-1]128
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Shock Absorber Clevis Bracket Pinch Bolt - AWD
[/SIZE][SIZE=-1]61
[/SIZE][SIZE=-1]45
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Shock Absorber Lower Mounting Bolt - RWD
[/SIZE][SIZE=-1]174
[/SIZE][SIZE=-1]128
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Shock Absorber Upper Mounting Nuts
[/SIZE][SIZE=-1]27
[/SIZE][SIZE=-1]20
[/SIZE][SIZE=-1]239
[/SIZE][SIZE=-1]Shock Absorber Shaft Nut
[/SIZE][SIZE=-1]95
[/SIZE][SIZE=-1]70
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Stabilizer Bar Link Upper (Shock) Nut
[/SIZE][SIZE=-1]128
[/SIZE][SIZE=-1]95
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Stabilizer Bar Link Lower Nut
[/SIZE][SIZE=-1]128
[/SIZE][SIZE=-1]95
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Stabilizer Bar Isolator Retainer Bolts
[/SIZE][SIZE=-1]60
[/SIZE][SIZE=-1]44
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Stabilizer Bar Heat Shield Screws
[/SIZE][SIZE=-1]7
[/SIZE][SIZE=-1]5
[/SIZE][SIZE=-1]62
[/SIZE][SIZE=-1]Upper Control Arm Ball Joint Nut
[/SIZE][SIZE=-1]47 + 90° TURN
[/SIZE][SIZE=-1]35 + 90° TURN
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Upper Control Arm Body Nuts
[/SIZE][SIZE=-1]75
[/SIZE][SIZE=-1]55
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Outer Tie Rod Ball Joint Nut
[/SIZE][SIZE=-1]85
[/SIZE][SIZE=-1]63
[/SIZE][SIZE=-1]—
[/SIZE][SIZE=-1]Tie Rod Jam Nut
[/SIZE][SIZE=-1]75
[/SIZE][SIZE=-1]55
[/SIZE][SIZE=-1]—
[/SIZE]
