2006 chrysler 300c hemi 5.7liter
I cant open my passenger door from the inside or lock it. Not sure what to buy to fix the issue or maybe a lock reset might help?
What I would try is to download the free demo version of AlfaOBD and pick up a cheap ELM327-compatible Bluetooth adapter. That should allow you to test the lock solenoids and either confirm or rule them out as the failure point.
There's nothing to buy, if you can't open it with the inside handle then there's a mechanical problem inside the door. Only answer is to take it apart to find it.
Those units come as a complete assembly if you find it’s bad also on my 2008 300c there’s a menu that comes up if I hold down the music note and the compass buttons on the steering wheel for about 5 seconds and a menu comes up that has different options to change the what doors lock and unlock when you hit the fob and Ck you window lock too
174805
