Pedders has been working on a special Camaro project. There is some information we can post in the forum and other information we are not allowed to post until it is released officially by GM. Based on the car that was displayed at the Woodward Cruise last week, we can release this information.
FRONT SUSPENSION
Front Geometry
Front Strut, Coil and Boot
Strut, Endlink and Tie Rod
REAR SUSPENSION
Trailing and Radius Arms
Forward Sub-frame Bush
Aft Sub-frame Bush
Coil Over Shock
Sway Bar, Endlinks and CV Shafts
There is no wheel hop in this chassis as is common with IRS vehicles. We can tell you that the IRS is robust. The front suspension slightly modified from the ZETA / VE / Commodore G8 with essentially stronger control arms designed to handle more power with larger wheel and tire combinations. The ZETA II Camaro may well be the most structurally sound vehicle in the GM line-up exceeding the strength of the 322 / CTS. Keep in mind the CTS is as strong or stronger than the alleged best of the best coming out of Europe.
The Camaro as delivered from the Dealer will be PERHAPS the best Modern Muscle on the road and with modification to the engine and suspension capable of running with anything short of the exotics. There is a reason Chevy built the ZR1. It is called the Camaro. in the nastiest version yet to be announced. In terms of what has been announced to the public, the Challenger and Camaro with be a heads up race on the road course or on the strip.
Riley Tech has been selected as the EXCLUSIVE builder of the Camaro for the Grand Am Challenge GS Camaro.
What you don't know and I can now say that Pedders worked with GM on the development of this vehicle. The Grand Am Challenge Camaro will run the circuit using what Pedders considers to be daily driver bushes and bits. The OE Camaro will arrive with hydraulically damped radius rod bushes. The OE radius rod bush performs well on the street for most drivers. For the enthusiast driver a hydraulically damped radius rod bush is about as useful as the wrong size driving shoes. They are too compliant. GM asked Pedders to develop a radius rod bush that would withstand the demands of track use. You will be able to buy EP6560C Camaro Radius Rod Bushes, the same bushes we developed for the Grand Am Challenge. It is the same bush we will be using as a basic component of the Camaro suspension.
The Grand Am Challenge is a full on race car. It does not use street style dampers and there are other revisions to the suspension and drive-line. These cars will also be using Pedders eXtreme Castor Washers in addition to the full on hard mount strut bearing with Castor and Camber adjustment. In the rear suspension Pedders EP7267 Toe Link Bushes, 5422 Toe Link eXtreme Washers and EP7266 Rear Control Arm Bush. In testing at the Milford Proving Grounds GM determined that our Pedders Bits met or exceeded their engineering and driving expectations.
Pedders is a unique company. We do not make parts for race cars. We do make some street parts that just happen to perform incredibly well on the race track. Our warranty is also unique. Pedders does not have a racing exclusion. You can take your Pedderised street legal Camaro to the track, flog it. If a Pedders part fails within 24 months or 36,000 miles it is covered under warranty.
We were absolutely thrilled to be invited to work with GM on the development of the Grand Am Challenge GS Camaro. We consider it an honor to have been selected for such a special project. Working with http://www.rileytech.com/ is another honor. I can't even begin to imagine a better way to introduce Pedders to the Camaro enthusiast community.
FRONT SUSPENSION
Front Geometry
REAR SUSPENSION
Aft Sub-frame Bush
Coil Over Shock
