Thanks in advance to anyone who can help/advise
Recently the headlight in my 2016 300c stopped working (all the other LED lights etc still work) so I initially thought it was the globe. After replacing the globe and finding out it still didn't work I ended up taking the car the the local dealer to get them to check it (along with fixing a few other electrical things that needed recalibrating etc). Upon collection they informed me that they could not fix it as they suspect it is a Ballast fault with the headlight and proceeded to quote $4500 for a whole new headlight fitted. I originally began to research a second hand headlight from a wreckers but as I did some research I saw that the Ballast unit is attached to the bottom of the headlight unit.
Question: Is it possible just to replace the Ballast unit on the bottom of the headlight unit in order for the headlight globe to work or does the whole headlight need replacing?
I have tried to look through this forum and google and YouTube and maybe I have just missed it but I can't seem to find an answer.
Thank you.
Thank you for your response. The model is 2016 Chrysler 300 C My16 4d Sedan V6.
A few months ago the drivers side globe went out and I purchased some 35W HID D3S globes, I purchased 2 but only replaced the one at the time and it worked. I have now used the other globe I purchased at the same time in the passengers side and it does not work. I tried swapping the globes over to make sure it wasn't a faulty globe but it worked in the drivers side. Since I have put in the new globe it worked once when I was driving the other night and went over a small bump that made it come on and stayed on until I arrived home 15 mins later but when I turned on the car again to check it wasn't working. Thought it may have been a loose connection or cable but checked that and it doesn't seem to be it either. The car dealers/service also checked basically the same ways and came to the faulty ballast conclusion.
Could I have messed up it up potentially months ago when I only replaced the drivers side globe? Should I retry with a new set of globes now?
Also can you confirm that if it is not the globes that I can change the ballast and not the whole headlight? and if this is the case do I have to replace both to match like your suggestion on the globes in pairs?
Again thank you for your help, really appreciate it
Which model car do you have? Are your "globes" HID? If you replace globes they should be in pairs and OEM quality. I would follow this procedure before changing ballasts.
2006 CRD Touring
Can you confirm that your globes are a quality brand, eg Osram? If not, you may be wasting efforts looking for faults elsewhere.
There are a number of DTCs (fault codes) associated with headlight operation, but you will need a good diagnostic (possibly diagFCA or AlfaOBD) to scan for these.
The ballasts can be detached from the headlight unit and replaced separately. I've never needed to replace a ballast during 16 yrs of ownership and I've only replaced the globes once - with Osram. Only one had failed but I replaced the pair.
There are numerous threads on this topic and I would recommend searching the forum for more information. I notice that some have been listed in "Recommended Reading" below this thread.
