No experience here, seems that your Outside diameter is more than 2/3" (0.67") bigger than stock 29.303" vs 28.629", couple that with your 1.6" drop and much fatter tires rubbing is no suprise. I don't know if this size is available but a 245/35/22 would result in an od of 28.751 which is nearly identical to stock (0.12"). This size tire I would expect would eliminate your rub. Do any other 22 runners have this problem, maybe your eibachs actually dropped you more than 1.6" if others with the same mod and size tire don't have a rub. If it is tire size and not spring error then the question of the day is: is a 245/35/22 tire available in a brand you want and what kind of credit do you get on a trade in if you go that route? Rubbing is dangerous and will result in eventual catastrophic failure most likely when you are rounding a curve on a two lane road approaching an 18 wheeler.
