On December 1, my right lead(pull) was fixed first time with a simple alignment. My car was built in early August.
The before-and-after alignment sheet says my toe was out of whack.
While writing this response I looked at the Alignment Spec sheet that was given to me when I got my car back from the dealer. The Model type shown on the Alignment sheet for the
Specified Range says "
300 Series: 2000-04 (300M)".
So it appears the dealers may not have the 2005 300 alignment specs loaded in their computers and must be referring to manuals and/or some other online data base. Somehow my dealer knew the correct specs, because some of the specs are way out of range (see Caster below).
Is it possible some dealers are using the wrong specs? Maybe the specs for the 300M?
-----Caster Front Left------------------------------TSB--------------
Actual__Before__Specified Range_______Preferred Recommended Range
__8.8____9.9______2.0 to 4.0___________10.3______9.0 to 12.10
----Caster Front Right---------
__11.1__10.5_____2.0 to 4.0___________11.10______9.0 to 12.10
---Cross Caster Front-----------
_-2.4__-0.6_____-1.0 to 1.0___________-0.80______-1.3 to -0.50
Here are the TSB spec's. Anyone with the right lead/pull problem should verify the dealer used the correct alignment specs for the 2005 300.
But I don't know if these specs are still the recommended settings. They could have since changed.
http://www.dodgemagnum.net/phpBB2/viewtopic.php?t=2438
REVISED ALIGNMENT SPECIFICATIONS
FRONT WHEEL ALIGNMENT - PREFERRED SETTING - ACCEPTABLE RANGE
CAMBER - LEFT__________________ -0.1°_______ -0.60° to +0.40°
CAMBER - RIGHT________________ -0.20°_______ -0.70° to +0.30°
Cross-Camber___________________ 0.20°_______ -0.30 to +0.60°
CASTER - LEFT________________ +10.30°_______ +9.00° to +12.10°
CASTER - RIGHT_______________ +11.10°_______ +9.00° to +12.10°
Cross-Caster___________________ -0.80°_______ -1.30 to -0.50°
INDIVIDUAL TOE_________________ 0.10°________ -0.05° to +0.15°
TOTAL TOE**__________________ +0.20°________ 0.00° to +0.40°
