1 - 2 of 2 Posts
How does one get the center console apart to remove the stock radio?
I have the Nav unit if that makes any difference.
Thanks.
Thanks.
Remove the ashtray or whatever you have there. Reach in with your fingers and pull out on the aluminum/wood fascia plate. Be careful, it's plastic but held by only a few clips.
As it comes loose, reach up along the sides and continue to pull outward. It goes back the same way.
Doesn't matter what radio you have. Then just remove its mounting screws and unclip the leads on the rear as you pull the unit out.
1 - 2 of 2 Posts
