1 - 18 of 18 Posts
Bas anyone changed their stock exhaust tips out for some fancy one using the stock exhaust if so post some pictures an the brand thanks in advance
I used a double wall, slant cut pair. 2.5" inlet, 4.25" outlet, about 8" long. Sorry but I don't remember who made them or the part number.
They were welded on and the resonators were removed so we had to make up some pipe to make the connection.
I always like the sound and drone cancelling capabilities of the oem resonators. I have a modded exhaust upstream but I kept the stock resonators but removed the outer chrome tip and left the "knub" of approximately 2.5" to fit all sorts of tips.
I started with the largest oval that would fit in the stock opening: Brand: TriHybers from ebay.
I then took the plunge and cut the opening to start fitting the wider quad exhaust options.
First up was a 3.5" tip made for a 997 Porsche 911: Brand: QSC from ebay.
Next were some Porsche 991.2 single tips: Brand: OEM Porsche
Then some 4" quad tips: Brand: from Ebay
Then some 2008 Mercedes S600 tips. These fit great but my bumper openings were too big by then: Brand: OEM Mercedes
Finally my current setup which is 4.5" quad Corsa tips made for a C7 Corvette. Started with them chrome, but settled on black:
I kept everything non welded so that I can make the precise adjustments I needed to keep everything flush and tucked. Ideally you want a tip shorter than 8" so that it tucks flush with bumper. My first ones were not tucked as much but I got better over the years by modding the spacing and bringing in the exhaust some more.
I like those black Corsa tips.
Thanks! I saw them on a Jeep and I really liked them!
I changed out my Magnaflow mufflers a few years ago for a slightly used Corsa catback. It has the single tips like the ones I had on the car but it sounds soooo much different.
Discussion Starter #9
I'm trying to get an idea for some nice exhaust tips since I was given a charger hellcat exhaust for free but had no tips so I'm looking for some stock exhaust tips of something aftermarket that looks good on a 300 srt8
They all look nice..what did you use to outline the bumper after you cut it?
Thanks! It's a flexible locking edge trim similar to the below:
Edge trim Black U extrusion medium size | U Height: 17/32", Grip range: 3/64" - 9/64" | PVC plastic edge protector (13 feet) https://www.amazon.com/dp/B017XQFG0M/ref=cm_sw_r_cp_apa_i_IstICb49EP2Y0
If you finish it with sandpaper down to about 2000 grit and it's a nice cut, you may not even need it. I think it looks good with or without it.
Where did you get the widened OEM rims from ?
I sent in a pair to Weldcraft located in Livonia, Michigan.
While on this topic, I changed up the tips again to Mopar square tips.
What all did you use to to make your bumper fit the quad tips
Nothing special, just a template, cut off wheel, 2" sanding drums and sandpaper to finish it off. I then added a locking edge trim to finish the edges.
When you got the wheels widened, does it ride different or does it feel normal
Its just like any wheel, perfectly normal.
I just installed some Michelin Pilot Sport 4S in 305/35/20 on them. The ride is perfect and the traction is unlike any other tire I have tried.
1 - 18 of 18 Posts
