1 - 2 of 2 Posts
I got the wheels for my car and I noticed that one front wheel sticks out more than the other. I have the same size wheels and spacers?? so what could be the problem?? someone said that it could be the car?? Could it be the car? Its not that bad but if you have someone stand in front you can see it.
Info, Hope It Helps
First Did You Have This Problem With The Wheels You Had On It Before.
If The Answer Is No, Then Possible One Of The Wheels You Got Has A Diffrent Offset. Try Change Tire From On Side To The Other And See If It Follow The Wheel Or Stays The Same. If It Follow The Wheel Then The Wheel Is The Problem And If It Stays The Car Is The Problem. Try Doing It With The Spacer Staying And Moving.
1 - 2 of 2 Posts
