1 - 20 of 23 Posts
Hey guys,
Heres my situation. When my daytime running lights are on and I put my turn signal on (left or right doesnt matter) when the turn signal flashes on, the daytime running light turns off. then when the turn signal flashes off, the day time running light turns on again (just the side that the turn signal is on). It pretty much flashes with the turn signal.
Is this normal?
I never noticed it since I can't see the front of my car when driving but I was driving behind my buddy and he said my light kept going out.
Yup its normal, same thing happens to mine. I've also seen other base/touring/limited's do the same.
Hey guys,
Is this normal?
Absolutely normal. It has to do with laws. There is a law that says something about if a turn signal is X amount of cm's from a daytime running light then the running light needs to be off. There was actually a news story about this a year or two ago.
no worries, glad we helped
i guess it is normal for chrysler. i am not sure about the law thing and have never seen it to happen, but on chryslers. there is no logical explanation for such feature to become a law.
on 300c it is not really noticeable as DLR and turn light share the same projector. however, i saw a new minivan couple days ago and the effect looked very odd as they apparently use underpowered low(or high) beams for DLR and it is very visible when one light goes off.
Is the only way to turn them off with a starscan tool?
If theres a DIY way, how?
Hey guys,
Is this normal?
Your buddy is watching your lights in his rearview mirror! Who's watching the road?
What you describe is not correct operation. I just went out in the dark, turned off the AUTO headlights, and turned on a turnsignal. The DRL on the signal side stayed off while the turnsignal flashed.
If you think think about it, with one or the other on when the other or one is off, you would hardly be able to tell anything is flashing, just flicking up and down!
Correct operation is that the DRL goes off and stays off , while the multi-function switch (aka the turnsignal stalk) is set in either signal position, to allow the amber turnsignal to be seen clearly.
Have you stood infront of your car with the headlights off and a turnsignal on? Try it and report back.
Im sure thats what he meant.
Like i said there was a news story about it, in which they indicated that there was some law/regulation/guideline for if a daytime running light is less then X cm away from the turn signal then the light must be out. Its a safty thing. with the day time light running at the same time as the signal then people might not be able to see the signal from some distance, which is why it turns off.
As written: "when the turn signal flashes on, the daytime running light turns off. then when the turn signal flashes off, the day time running light turns on again (just the side that the turn signal is on). It pretty much flashes with the turn signal."
How could the above mean anything else, especially "It pretty much flashes with the turn signal."?
He needs to stand in front of his own car and see it for himself, and then report back EXACTLY WHAT HE SAW.
What could be simpler?
I hear you bro. :) However, I do not recall seeing any other make with such effect. Do not they have to abide the regulations too?
On another note, we all know that clowns write not only news articles, but regulations as well. I drove in various jurisdictions requiring DRL. I do not recall seeing (or imagine) white light DRL ever obstructing amber (yellow) turn signal no matter now close they are.
The only case turning off one DRL may help if DRL is amber coloured light. This is allowed here and some manufactures use it (older Chrysler minivans). I do not clearly get why the variation is allowed at all and DRL was not limited to white only light. At the same time in the minivans one DRL has to go off anyway as it is the same light as turn signal.
Discussion Starter · #14 ·
heh sry i didnt get back sooner, umm ya i think the DTR light statys off while the blinker is on. so it seems all is normal.
i havent gone out to check it yet since im not at home till later tonight but i think it did stay off.
:fing02: For you.
:thumbsdow: For your buddy.
I hear ya, dont know how long they have required it that way, i now what you mean about how it seems chrysler is the one mainly doing this, I have seen a few other cars doing this aswell. I think the requirement was a gap of 10 cm (not 100% sure).
All i said was "im sure thats what he meant" meaning that is probably what he was trying to say. Not your wrong and I dont see what your going on about. I hope you didnt take it as me saying something -ve towards you. :grouphug:
No foul!
You took his explanation as being questionably worded, and gave him the benefit of a doubt. I didn't doubt his wording. I took his explanation literally. He thought he had a problem, which it would have been if it existed as described.
If someone had told me that my DRL's flashed on and off in opposite sequence to the turnsignal the first place I'd have gone would have been to the front of the car to see for myself. And that would have been that!
He has yet to look for himself.
1 - 20 of 23 Posts
