1 - 3 of 3 Posts
A friend gave me a Chrysler 300 c hemi . It has been taken over by the rats and mice. Under the hood they have made beds. So now it’s cleaned up it looks like they chewed some of the wires. The wiring harness that goes to the spark plugs. Some are not bad. Just wire is showing. I wrapped them with electrical tape. But one is pretty bad. Can I fix it and how
First, avoid electrical tape if at all possible. Underhood, that's a recipe for disaster.
Use heat-shrink tubing if you can get at both ends of the wire, otherwise you can use heat-shrink tape, or some wire loom.
For wires that were chewed all the way through, you can either solder the connections or use solderless butt connectors or something similar.
1 - 3 of 3 Posts
