I was just wondering if any of you guys are running anything else other then UAS in the rear of your cars. I know MIC uses firestone 2500 lbs bags and they are getting hella lift. What they did was offset the cups to clear the bag when fully collapsed which makes sense to me. The bag they use is 6.4" diameter @ 100psi. If this is the case and they can fit this with out rubbing issues then I should be able to get a RE6 in there with no problems at all. The RE6 is 6" diameter, 200 psi max recommended, 7.2" of stroke, 1,571 lbs of force at maximum stroke (80psi), and have a collapsed height of 2.9". Uas has a bag that is 2.0" Compressed, 7.0" Extended, and 5.875" Diameter. Makes me think my lift issues isn't a cup issue but a bag selection issue. Good thing I can steal the bags from my ram to test!
