1 - 11 of 11 Posts
Since the weather is getting cooler, the need to defrost the windows and mirrors have started. I rarely need to use the rear window defrost, but would like to use the heated mirrors (which is activated with the rear window defrost). My question is, has anyone had any issues with the use of the rear window defroster when there is window tint, ie peeling, melting, bubbling etc...
Have used the R/D a few times
Haven't noticed any problems yet. My tint is about four months old.
There shouldn't be any problems if your installer used a quality tint film. My installer told me that if I used my rear defroster, that it would help to work the air bubbles out of the film, and that was in June.
I haven't had any problems at all with the film they installed.
I have had window tint on the rear window of many cars that I have owned (including my 300C) and have NEVER had any heating issues with any of them.
No need to worry... :silly:
You are fine. That defroster doesn't get THAT hot. I've had 3 or 4 cars with rear defrost and tint; it's never been an issue at all.
Only issue I know of is if you used a metallic tint then you may have less AM radio reception; I researched this before I had the tint done and decided I could live with it since I never listen to AM radio anyway.
dont worry you wont have any issues.
your defroster won't make the window and tint film any hotter than the sun will with the car sitting in a parking lot in the direct sunlight!! you'll be fine!
like everyone said there should be no problem because most back window tint is melted to the shape of the window so there is no risk of it ever peeling by the elements.
1 - 11 of 11 Posts
