I just called to extend my warranty and found out there were two recalls due to the radiator. Not quite sure what this consists of but I'll keep you guys informed. Anyone with info on this.
I use to have a base 300 and one recall i had was the radiator brackets needed to be replaced. i dont know what the other one could be. hope that helps. if you do a search of the site there is a complete list of all tsb's for the lx platform i beleive. good luck :wave:
recall
1 is for the radiator bracket and the other is to check the anti-freeze to see if it is set low enough to keep from freezeing.
Go to the Chrysler website and type in the last 8 digits of your VIN to see if your car is under any recalls. There have been more than 2 recalls, but not every recall effects every car. http://www.chrysler.com/webselfserv...recall&country=us&emailUrl=goToEmailForm('R')
This is copied from the TSB thread.
2. RECALLS
11/22/05 … 0506 … RC-E14 … Transmission Cup Plug Bracket … (3MR)
09/04/04 … 2005 … RC-D38 … Emissions Recall - VECI Label Replacement … (CM)
07/02/04 … 2005 … RC-D21 … Safety Recall - Rear Floorpan Reinforcement Spot Welds … (3M)
07/02/04 … 2005 … RC-D28 … Safety Recall - Battery Cable Bulkhead Stud Fasteners … (3M)
07/02/04 … 2005 … RC-D30 … Safety Recall - Shoulder Belt Adjuster Turning Loop Bolts … (3M)
05/01/04 … 2005 … RC-D25 … Emissions Recall - Replace PCM and Install Correct Software … (C)
3. CUSTOMER SATISFACTION NOTICES (CSN's)
12/22/04 … 2005 … RC-D36 … Instrument Cluster Gauge Accuracy - reprogram gauges … (3M)
11/01/04 … 2005 … RC-D49 … Compact Spare May Contact Front Susp. Ball Joint Stud … (3M)
11/01/04 … 2005 … RC-D50 … Radiator Isolator Brackets may crack … (3M)
11/01/04 … 2005 … RC-D51 … Low Anti-Freeze Concentration Level … (3M)
07/02/04 … 2005 … RC-D29 … Reprogram PCM - Electronic Throttle Control … (3M)
06/17/04 … 2005 … RC-D27 … Tire and Loading Information Label … (3)
joey said:
....This is copied from the TSB thread.
Thanks Joey...
And once again, that TSB thread, which ResumeSpeed created, and faithfully updates, can be located at the top of the "Problems / Dealer Service" forum as a sticky thread. Please refer to the TSB thread often to keep yourself updated. You just may find the answers to some of your questions there as well :wink1:
Discussion Starter · #7 ·
Joey right on the money, those were the two. Now to schedule a service date and be without my hemi for a bit..... :eek:mfg:
