1 - 1 of 1 Posts
The tsb's I found with the search button only went up to November. Here are the most recent ones.
Make : CHRYSLER Model : 300 Year : 2005
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 2100205 Date of Bulletin: JAN 14, 2005
NHTSA Item Number: 10012339
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
TRANSMISSION FLUID MAY BE WICKING IN THE RIGHT FRONT CORNER OF THE TRANSMISSION OIL PAN AREA. *EH
Check to Request Research. Submit below.
Service Bulletin Num : 1800305 Date of Bulletin: JAN 12, 2005
NHTSA Item Number: 10012327
Component: ELECTRICAL SYSTEM
Summary:
HEADLIGHTS FLUCTUATION AND OR INTERIOR LAMPS FLUCTUATION. *EH
Service Bulletin Num : 1804404 Date of Bulletin: DEC 08, 2004
NHTSA Item Number: 10011927
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
COLD START IDLE CYCLING OR RADIATOR STEAMING AT IDLE. *TT
Service Bulletin Num : 36 Date of Bulletin: DEC 01, 2004
NHTSA Item Number: 10011936
Summary:
INACCURATE SPEEDOMETER, TACHOMETER, COOLANT TEMPERATURE, AND FUEL GAUGE READINGS. CUSTOMER SATISFACTION NOTIFICATION D36. *TT
Service Bulletin Num : 1901004 Date of Bulletin: NOV 29, 2004
NHTSA Item Number: 10011958
Component: STEERING
Summary:
POWER STEERING FLUID CONTAMINATION. *TT
Service Bulletin Num : 0901504 Date of Bulletin: NOV 04, 2004
NHTSA Item Number: 10011560
Summary:
ENGINE OIL VISCOSITY GRADES FOR 5.7L MULTIPLE DISPLACEMENT SYSTEM (MDS). *TT
Service Bulletin Num : 49 Date of Bulletin: NOV 01, 2004
NHTSA Item Number: 10011550
Component: TIRES:TEMPORARY/EMERGENCY SPARE TIRE
Summary:
CUSTOMER SATISFACTION NOTIFICATION D49. COMPACT SPARE WHEEL. THE WHEEL FOR THE COMPACT SPARE MAY CONTACT THE FRONT SUSPENSION LOWER CONTROL ARM BALL JOINT STUD DURING CERTAIN VEHICLE MANEUVERS. *TT
Service Bulletin Num : 50 Date of Bulletin: NOV 01, 2004
NHTSA Item Number: 10011551
Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM:RADIATOR ASSEMBLY
Summary:
CUSTOMER SATISFACTION NOTIFICATION D50 RADIATOR ISOLATOR BRACKETS. THE RADIATOR ISOLATOR BRACKETS MAY CRACK. *TT
Service Bulletin Num : 51 Date of Bulletin: NOV 01, 2004
NHTSA Item Number: 10011552
Summary:
CUSTOMER SATISFACTION NOTIFICATION D51 ANTI-FREEZE CONCENTRATION LEVEL. THE ENGINE COOLANT MAY HAVE A LOW (WEAK) ANTI-FREEZE CONCENTRATION LEVEL. *TT
Service Bulletin Num : 0803104 Date of Bulletin: SEP 29, 2004
NHTSA Item Number: 10010481
Summary:
INSTRUMENT CLUSTER LANGUAGE (NON-ENGLISH) SELECTION IS NOT SAVED. *TT THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-031-04 DATED 09/08/04. *TT
Service Bulletin Num : 2303804 Date of Bulletin: SEP 23, 2004
NHTSA Item Number: 10010492
Component: STRUCTURE:BODY
Summary:
REAR DOOR GLASS BINDS. *TT
Service Bulletin Num : 0803204 Date of Bulletin: SEP 22, 2004
NHTSA Item Number: 10010482
Summary:
POOR RADIO RECEPTION. *TT
Service Bulletin Num : 1800904 Date of Bulletin: SEP 13, 2004
NHTSA Item Number: 10010485
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
GENERIC POWERTRAIN CONTROL MODULE (PCM) PROCEDURE. THIS BULLETIN SUPERSEDES BULLETIN 18-009-04 DATED 03/02/2004. *TT
Service Bulletin Num : 38 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10010494
Component: EQUIPMENT:OTHER:LABELS
Summary:
EMISSIONS RECALL D38 - VECI LABEL REPLACEMENT. AN INCORRECT VEHICLE EMISSION CONTROL INFORMATION (VECI) LABEL WAS INADVERTENTLY INSTALLED. *TT
Service Bulletin Num : 0424 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10010497
Summary:
ALL WHEEL DRIVE A580 TRANSMISSION FAST FEEDBACK PROGRAM. *TT
1 - 1 of 1 Posts
