:pat: WANT TO REMOVE MY CHROME MIRRORS-DOOR HANDLES ,WANT TO GO ALL BLACK.I BOUGHT THE KIT ON E-BAY LAST YEAR,THEY ARE ON THE WITH THE 3M TAPE.THE PROBLEM IS THE TAPE IS IN THE MIDDLE OF THE MIRRORS AND HANDLES CANT GET TO TAPE UNLESS I PULL BACK ON THE CHROME DONT WANT TO BREAK THE PEICES.DID ANYBODY PUT THESE ON THERE CAR AND REMOVED THEM.THANKS
I can imagine if you use some WD-40 or some GOO GONE that you will be able to disolve the glue on the tape enough you can get if off of there... time and patience will probably be your biggest enemy as you are not going to want to rush the process.
Thanks,thats What I Used On My Moldings And It Worked But Like Said The 3m Tape Sits Right In The Middle Of This Stuff.the Problem Is There Is No Where To Peel Back Like The Moldings.i Guess Your Right Time And Patience.i Knew This Was Going To Happend Changing My Mind With The Chrome.
Try a heat gun and if you dont have that a blow dryer....get it hot enough to where you can pull them off (might want to use gloves or rag in case it's too hot) then just clean off the glue/tape
I Will Give It Try Thanks.just Going To Wait For Spring To Do This.4 More Weeks Cant Wait!
