If you have a good re-poor with your dealer he might print you directions how to remove it . You have to remove the side Bolsters ,remove the bolt on the bottom and with a flat bar push down on the clip at the top. Behind the bolster and pull it out , if you have side curtain air bags be careful when removing the C-Pillar trim (refer to 23 Body/Interior/C-Pillar Trim-Removal) . Lots of luck
moddog
