How long was it in your car before it exploded? Did you do anything in particular the night it exploded?300Con23s said:Be extra careful when adding a higher watt bulb. I remember I put a 80w/100w bulb in my Jeep and the bulb exploded in the headlamp housing and trust me you don't want that to happean.
please keep us posted as to durability , problems etc.ktan23 said:Replaced the stock bulbs tonight.. let me know what you think..![]()
bulbs i used to replace the stocks
stock bulbs..
I wanted my 300C with the factory blue lights....but it didn't quite work out that way.... I got similar after market bulbs & they look spectacular!!!! But make sure you do the high beam, low beam, and the fogs.....ktan23 said:Replaced the stock bulbs tonight.. let me know what you think..![]()
stock bulbs..
What is a heavy duty double relay harness? Can you see a significant improvement in visability over stock? I have the HIDs but I might try these for the high beam.HERMINIO said:ktan23, those are the same I used to replace my non-HID one, high and low beam but I added a heavy duty double relay harness for protection.
I tried several makes/wattages but these ones are the best of all tested. The difference is awesome as you pictured.
