1 - 8 of 8 Posts
I just wondered if anyone else has this problem?
since day one, my CD's skip every now and then, I noticed it's nothign to do with bumps in road when driving.
I could take it to the dealership but I am reluctant since it's such a hassle.
If I wanted to replace the unit is there something that you can suggest that will fit the factory opening?
Thanks,
Thanks,
I have this problem and mentioned it when I took it in for the first check up.
Just the other day, it completely went haywire, and now, it won't read any of the six disks in the changer. I called yesterday and have to take the car in. Yours could lead to this too, you may wanna watch it.
Discussion Starter · #6 ·
ok, thank you, for the info, I have a feeling it's not going to magically go away either and for it to get worse, good point.
I actually wouldn't mind finding a nice aftermarket replacement.
Do you know of any?
I'm in the same boat as you...I'm considering a replacement because, have you noticed how inconvenient the placement of the buttons are?
On top of all that, how are you gonna give me a six disk changer, and I don't even have a repeat button anywhere on it???
Do you know if you install subs and an amp does that void your warranty?
Due to the vehicle's can-B bus data system, you can cause issues with the electrical system that may not creep-up for days, weeks or months. If you cut and splice into any wire, you are asking for trouble.
1 - 8 of 8 Posts
