I keep getting rke battery low warning. I replaced battery 2 wks ago....where else should i look???
Although unlikely, the replacement battery might have been bad. Try buying another one from another store.
Your key may also be faulty and will need replacing. The key is covered under the factory 3/36k warranty. From your profile it looks like you have a 2005 car which would be out of warranty. If you have an extended warranty the key might be covered under it.
Also, check the inside of the key for a loose battery clip/bracket.
It is the piece of metal that holds the battery. This piece can sometimes be fixed with solder. I tried soldering mine but the piece popped out again.
I eventually replaced my key under warranty.
Thanks Desiree and others,,, out of warranty so I guess soldering is the best option
