Glide feature on drivers seat and memory feature on key stopped working even though (evic) display shows features are ON. Anyone experience similar problem and or have a fix?
You'll have to reprogram trhe EVIC to permit the seat to move back. Somehow, it probably got changed. Another possibility is that the seat is too far back so that it can't move. There is a position in the backward state whereby it will not move backward farther.New Chrysler Guy said:Glide feature on drivers seat and memory feature on key stopped working even though (evic) display shows features are ON. Anyone experience similar problem and or have a fix?
Like anything electronic, stuff happens. But the problem may be as simple as the glide and steering controls not enabled in the EVIC.Commonbelief said:... It needed a new seat module. I got the car back today and guess what. The seat wont go back on its own and neither will the steering column! I went through the manual to see if I was freakin out and doing something wrong. It appears that I am doing the right things, I dont get it. I love the new cars from Chrysler, but I still hate their dealerships.
As I said, stuff happens to electronics, but suggest you follow what was suggested in the earlier post. Most of the time that covers the problem.Billy94Z said:I have this problem as well.
Miles,mileshoover said:Like anything electronic, stuff happens. But the problem may be as simple as the glide and steering controls not enabled in the EVIC.
Suggest first check the EVIC, Personal Settings and be certain they are enabled. Another reason the glide won't work is that the seat is adjusted too far back. Also, be sure that the settings for the seat, once enabled, must be saved on the appropriate setting switch on the driver's door. Your owner's manual is quite clear on how to do this. But be sure to follow the directions on the yellow addendum for memory controls.
It certainly appears as if your dealer should have reset things properly since apparently that is the reason for the work you had done. Remember, the customer controls their continuance of the 5* rating. Don't be afraid to speak up via the Regional Rep and/or DC itself. They DO listen to valid customer complaints. On the other hand, also be sure where the problem is -- you or them. :^))
