07 300 Is there a definite answer about making the car start again when it goes into immobilizer mode? I left the key in the on position for 10 minutes, makes no difference, turn key doesn't turn over, there has to be a way to reset the system? I have unhooked the negative battery terminal now and will let it set overnight, any suggestions welcome.
2014 CRD
Yes I'm assuming there should be codes if this is happening. Have you tried your OBD2 reader an if so what do you see?
Also try the keydance: Link
Discussion Starter · #5 ·
absolutely zero codes, I disconnected the battery overnight after trying other things, when I turn the key to run the security light acts just like my 06, solid on for like 5 seconds then goes out, no flashing or staying on.
