HEY GANG,
ok, I've been doing my research about towing with the SRT8, and still trying to get some real numbers to go off of.
First of all, PLEASE do not reply with "why would you tow anything with the SRT8", or anything similar. I would like constructive help, not criticism. I cannot stress this enough, I've seen other posts and that seems to be a running theme. I get it. However not all of us can afford a second vehicle or even want one, just for towing.
This is my idea/plan/desire:
I want to get the Mopar Hitch installed on my 2007 300c SRT8, and use it to tow around a small-ish caravan (trailer camper, whatever you want to call it, I'm not sure). I have recently rented out my home, and I want to full-time it in various cities while working my gigs. I would only tow it when moving from one RV park or campground to another. Maybe once or twice a month, not daily, not often.
I would likely get a 20 foot or so caravan, which would have living quarters in it, basically an RV but a trailer version. I'm trying to get some fairly accurate numbers with regards to the max tongue weight and overall trailer weight. I've seen posts of people hauling some pretty heavy weights around, and from what I've read the hitch is rated for 3800lbs on certain 300 models (AWD? 5.7?). Also stated is a 2000lb max and 200 tongue weight.
I'm aware there are no real hard numbers available as it's "not reccommended" for the SRT8 to tow. However we all know it can do it. Anyone who HAS EXPERIENCE in this regard please let me know.
Main questions:
1. What is the max trailer weight and tongue weight (realistically, not just what is officially stated with the Mopar hitch) (this affects the overall length of the trailer and the amenities)
2. Should I look for a trailer with it's own brakes ?? (I know we have great brakes but anything to reduce the strain
3. Transmission ?? Seems like it would hold up fine, I'm at 70,000 miles right now and am about to do the fluid replacement on the tranny.
I know this is against the normal thinking of the use of our vehicles, but I tend to walk my own path in life and think outside the box. From the research and OLD info I've found on this forum and others, it seems the SRT8 should be able to handle significant weight.
I'm not trying to break my car. I plan on keeping this car FOREVER. It is my baby for sure. I'm aware there could be some risks, but it seems minor considering the build quality and capabilities of our engines, trannys, and suspension components.
That said, it would be amazing to be able to just book my gigs out in advance, and go from city to city, living in the trailer, and having my car available to get around town in style. It also would DEF attract attention, which is not a bad thing when you are an entertainer like myself.
I BELIEVE THIS IS POSSIBLE SO ANY HELPFUL AND INSIGHTFUL INFORMATION SOME OF YOU MIGHT HAVE WOULD BE GREATLY APPRECIATED.
This forum is the bomb and if the general consensus is it can be done for my purposes, then I will go ahead with it and document everything !
Otherwise I'm just gonna get an RV.....(then I got no car to get around in)
PEACE Y'ALL
Main questions:
PEACE Y'ALL
