1 - 20 of 30 Posts
Calling NMG
I have noticed that some models have a black cover on top of the shocker towers and some do not
I have a 2007 build 3.5 and it dosent have them
I have seen 2 2007 CRD,s and 1 did and 1 didnt have them
Jamie should I have these , Just in case I got a Friday Car :)
The shock tower covers were axed in early 2007. The one with them probably was built earlier than the one that had them.
Bernie
You can get them at the MoparSuperCenter and they're not expensive - LX Strut Tower Cover.
Bernie
And they look better when color matched to the car... depending on the car color... black looks great on some.
I know 402 Motoring was doing them when they were vendors. Not sure if anyone's doing it still though.
Bernie
I just checked it out.... And not sure if i saw the right price.....
Is it like about $6 only?!! Hmmm pretty cheap I say.....
Yeah, but the shipping to Australia would probably be a lot more. I bet you can order them through a dealer there for less.
Bernie
Hmmm I haven't even looked under my hood to see if I have them or not.....
I guess if Jamie can do a good price I'll Check to see if I don't have them.... I go get it from him....
Discussion Starter #9
Bernie
Thanks Bernie
They look a lot neater with them on I wonder why the discontinued them
Thanks Bernie
It's a bean counter thing just like the headlight washers. Added up even at this low cost probably saved them hundreds of thousands of dollars, maybe millions for all I know...haha.
Bernie
Discussion Starter #11
Bernie
We have the washers here but im not sure if they are on the series 2
Useless things in my opinion
ADRs here in Australia require headlight washer as mandatory for Xenon lights (I believe), so no chance of them being deleted for us.
Also in NA, Xenons are not standard of 300Cs, or didn't used to be.
Discussion Starter #13
John
Im not a user manual reading person as you can see ,but how do those washers work ?
Do they come on with the screen washers or is there a seperate function only for the lights
I drive a S class Benz for work and if i hit the headlight washers it oversprays soapy water over the hood and the screen
I think you're right on that John. Hope you're doing OK there man!!!
Bernie
John
Good question wozza. I'll try this from memory and stand to be corrected okay? :)
I believe when the wipers are on and on the third use of the washers the headlights get a flush.
Bernie
Bernie, thanks mate. Doing okay, on my second dose of drugs now and suffering little side affects.
John
Great question. How do they work? I have not even open the book yet.
This forum is the best user manual.
First, good to hear John. Now if my memory serves, you set the headlight washers on or off in the EVIC menu. I have mine set to off...haha.
Bernie
Headlights on, hit the windscreen washers. Pretty sure it's one in three goes, but also number of ignition cycles in between will affect this.
As Bernie said, they disappeared in early 07. I agree, they do look unsightly without.
I'll get Jamie to price them up, knowing our system... they'll probably be over $50 a pop. So if that's the case, might be worth someone organising a group buy from the supercenter.
Hey, that's cool! I didn't know you guys had your own Mopar Parts vendor.
Bernie
1 - 20 of 30 Posts
