Many Mercedes models have various size spring pads that can be used to vary the cars height. The size of the pad is indicated by the number of "bumps" on the pad - but only varies by small millimeters. I found a similar spring pad only on the Magnum front suspension this weekend. Oddly, I could not find anything similar visable on the rear.
Here are the spring pads and 'bumps' for W210 E-Class cars:
FRONT SPRING PADS
1 bump 5mm
2 bump 9mm
3 bump 13 mm
4 bump 17 mm
5 bump 21 mm
REAR SPRING PADS
1 bump 5mm
2 bump 9mm
3 bump 13 mm
4 bump 17 mm
FRONT SPRING PADS
1 bump 5mm
2 bump 9mm
3 bump 13 mm
4 bump 17 mm
5 bump 21 mm
REAR SPRING PADS
1 bump 5mm
2 bump 9mm
3 bump 13 mm
4 bump 17 mm
