1 - 2 of 2 Posts
Hi guys, I have a 2006 300C SRT8 and the time has come to change the springs and shocks/struts. I like the original ride height. I live in NYC and between the potholes and the speed bumps, quite frankly, I need the original ride height. I would like to change the springs, but everything out there seems to be focused on lowering. I do not want to lower my car. After doing some research, I found that I am limited to a few options. Can someone confirm that the following spring rates are correct? And if so, are the spring heights equal? I am thinking of putting the OEM Charger SRT springs on my 300 SRT. Will this work? And if it will work, what are the part numbers? I looked at the parts listings and there are about 20 different part numbers for the springs alone! Finally, if I can put the Charger SRT springs on my 300 SRT, which shocks/struts are best . . . Bilstein, Pedders, Eibach? Thanks in advance for your help.
Spring Rates:
Stock 300C SRT8
227 lb/in front
622 lb/in rear
Stock Charger SRT8
284 lb/in front
778 lb/in rear
Discussion Starter #2
Can anyone please help here?
1 - 2 of 2 Posts
