1. looks like it will have dual filters.
2. rear brake has an odd placement?
Is wheel travel such a bad thing?E55 KEV said:COMPLAINT - Still a lot of wheel well gap!![]()
It has nothing to do with "wheel travel", but the original design. You can have the same length of suspension and parts and not have the unsightly gap. Actually the car is not high off the ground (comparing the chassis ground clearance) it just has the unnesseary gap. If you can design it in, you can design it out, just like BMW does. All BMW cars have minimum wheel gap because they put a little more sheet metal around the fender lips which merely give the appearance of lowered. All they had to do was add a little more sheet metal around the fender wheel wells.Redman said:Is wheel travel such a bad thing?![]()
Is not the alternative a stiff, buckboard ride not commensurate with "luxury" car-like ride features?
You're absolutely right KEV and it's my biggest complaint with these cars as well. It is something that we constantly strive to correct in our streetrods, and when it cannot be achieved with wheels/tires, it is a PITA to attempt to achieve with sheet metal or f'glass and still maintain the correct radius. I would have thought this would have been addressed in the design of the SRT-8. Certainly anyone that had the foresight to develop so unique a car in the first place should be able to recognize such a glaring flaw and re-engineer it. This, the missing chrome and the lack of a set-apart design feature as compared to the other models, has me second guessing my desire to trade when the time comes... doesn't exactly seem like a trade UP, especially considering all the additional negatives that have been posted previously.E55 KEV said:It has nothing to do with "wheel travel", but the original design. You can have the same length of suspension and parts and not have the unsightly gap. Actually the car is not high off the ground (comparing the chassis ground clearance) it just has the unnesseary gap. If you can design it in, you can design it out, just like BMW does. All BMW cars have minimum wheel gap because they put a little more sheet metal around the fender lips which merely give the appearance of lowered. All they had to do was add a little more sheet metal around the fender wheel wells.
Red,Redman said:Is wheel travel such a bad thing?![]()
Off with their heads!!E55 KEV said:The problem with tyring to eliminate the wheel gap will be - there is almost 1.5 to 2" of unnecessary gap built into the car. However, when you use lowering spring to correct it - visually the wheel wells look great but now the car's chassis is too low to the ground and will be scraped all the time.
I see 2 boxes on the intake. The standard 5.7L MDS Hemi does not have the box on the left.NIGHTMARE said:I only see one filter.
The box on the left is an air silencer. The box on the right is an air filter boxE55 KEV said:I see 2 boxes on the intake. The standard 5.7L MDS Hemi does not have the box on the left.
werd. Its so you dont get that Honda sound when you crack the throttle.Redman said:"Air silencer" - that implies mach force winds, no?
Welcome! Gotta go where the action is and the 300C and Magnum are Hot! You have a 300C Hemi also?1SICKLEX said:E55 KEV, wow your the Admin here. I've seen you on MBWorld. Nice site here.
