Here's a little more on this:
FRONT SUSPENSION - SRT8
The SRT8 front suspension is very similar to the standard RWD front suspension but some components have been modified for better handling and durability. Most component bushings are increased rate bushings. Service of all front suspension components remain the same as the standard RWD components. When components differ, be sure to use only SRT8 components on SRT8 vehicles.
The front knuckle for the SRT8 is different from the standard RWD knuckle. Although similar in appearance, the knuckle has been modified to accept the larger 20 inch tire and wheel assembly. Also, the mounting bosses for the disc brake caliper have been moved downward to allow for mounting of the Brembo four-piston disc brake caliper.
Bernie
