You bet. Have you located a 180 degree thermostat, presuming that is what you are after? I understand Mopar performance makes one as does Evans Cooling, among others. I have not confirmed that either of the named manufacturers make one that is compatible with our 8's though.qictrk said:Thanks 3SRT4ME. Cecil.........
I partially agreevvv90 said:OH GAWD! Not this again.
Listen, swapping your thermo does nothing to cool the car. That's what your fans and radiator do.
At 180 vs. the 195 it will take you car longer to heat up and that doesn't serve any purpose. The only other thing the thermostat controls is flow capacity which is important but that doesn't have anything to do with the temp rating (if I'm not mistaken.)
I used to think the 180 would be alright so long as you could do a fan mod which is what the GSM mod looks like it will do. However, I'm convinced the SRT-8 is engineered to perform best around 195-210.
I'm sticking to this theory until somebody can show me more power produced on a dyno at 180-185 vs. 195-200.
QuikSilver said:I partially agree
If you can run @ 180 and advance the timing a couple of extra degrees at low-mid rpm's with some added fuel (hence more tq) this is where having a 180 degree thermo may help. Otherwise you're probably correct on the 195.
Do post what you learn regarding this combo would you, thx.qictrk said:I'm putting on the Jet Chip and the override switch from GSM. I had the impression that the 180 would help with these two changes. Maybe not, I'll have to check with GSM. Cecil............
There are quite a few dynos sheets on this forum with and without heat soak(205+)...OH GAWD! Not this again.
Sorry man, I dont know how I missed that your post was over a year old.Yeah now there are....There certainly weren't 1.5 years ago when I said that.![]()
Cycling the car on and off in the staging lanes is one way.Yeah now there are....There certainly weren't 1.5 years ago when I said that.
I still have yet to see anyone keep their 6.1 below 205 without going with both a fan mod and thermostat.
Sorry man, I dont know how I missed that your post was over a year old.at:
Not where I go. You're constantly moving around. The times I was able to shut the car off however the temperature stayed at 210+ or went up which makes sense because if the coolant isn't moving it can't cool. I've been wanting to try icing the manifold because that seems to be very worthwhile for better times.Cycling the car on and off in the staging lanes is one way.
It's a 203.It's a 195 degree thermostat, right? Cruising on the Hwy it sits at 195 degrees in 60 degree weather...
